Top » Catalog » Lighting » My Account  |  Cart Contents  |  Checkout
Quick Find
Use keywords to find the product you are looking for.
Advanced Search
Categories
Accessories (1)
DIY Parts (1)
Engine Parts-> (14)
Lighting (3)
Merchandise (3)
Megajolt Ignition-> (11)
Write ReviewWrite a review on this product!
Information
Find a Distributor
Shipping & Returns
Privacy Notice
Conditions of Use
Contact Us
Languages
English
Currencies
Cluster LED module (For shift light) $5.95
Turn this LED module into the ultimate DIY shift light (empahsis on DIY!!)
The cluster combines 6 high brightness red LEDs and 10 high brightness yellow/green LEDs into a single housing about 1" (25mm) in diameter.
A single mounting stud on the rear allows panel / dash mounting. 3 wires are used to energize the cluster:
white: +12v
red: GND for red cluster
green: GND for yellow/green cluster
The module is designed to work directly from 12V, and will integrate perfectly with the MegaJolt Lite Jr. Shift light or programmable output.
As this is a surplus item pulled from a digital electronic sign, some scuffing on the outside may exist. All units will be tested in advance.
Discuss / see more details on this item
This product was added to our catalog on Tuesday 27 March, 2007.
Customers who bought this product also purchased
GM Air Temperature Sensor
GM Air Temperature Sensor Pigtail
GM Coolant Sensor Pigtail
GM Coolant Temperature Sensor
Tach Adapter
Tach Adapter
Compact USB-Serial Adapter
Shopping Cart
0 items
Notifications
NotificationsNotify me of updates to Cluster LED module (For shift light)
Tell A Friend
Tell someone you know about this product.
HEADING_TITLE Copyright © 2012 Autosport Labs
Powered by osCommerce
HEADING_TITLE
