Kit to convert a TPS-optioned V4 Megajolt Lite Jr to use a MAP sensor.
Includes:
Qty 1 - Freescale MPX4250AP pressure sensor
Qty 2 - 0.1uF 1206 surface mount ceramic capacitor
Qty 1 - 1206 270 ohm resistor
The conversion is straightforward, but requires precision soldering skills. Follow these steps:
1. Complete this section of the Kit assembly guide.
2. Disconnect the TPS Input to allow correct MAP sensor operation.
3. Drill a hole in the end plate where the MAP sensor nipple will extend.
- You can use the mounted MAP sensor nipple to make a light indentation onto a thick piece of tape adhered to on the back side of the enclosure end plate.
- After marking, remove the end plate and drill a hole to match the diameter of the vacuum line you will be using.
Discussion Forums
