New multi-zone tire temp sensor – TireX pre-orders start soon!
tirex_rendering
Subscribe to get early bird pre-order pricing
TireX is a thermal-imaging sensor that visualizes how your tires are working, in real time.
Use it to tune your suspension for maximum grip and balance.
tirex3quarter
Compact CNC aluminum enclosure • IP65 rating • Plug and play CAN bus connection with optional harness
tirex_rendering
Click here to view full specifications, wiring and CAN bus protocol
Wide field of view works with your tight fenders and wide tires
110 degree FOV simultaneously reads multiple zones across your tire
tirex_temperature_measuring
tirex_tire_temp
Compatible with Podium real-time telemetry – easily analyze tire temperatures right from the pits
Compatible with any CAN-bus enabled data system
RaceCapture • AiM • MoTeC • AEM – and more
Simple CAN bus protocol makes integration easy with virtually any system
