Exciting news from Autosport Labs: RaceCapture software just leveled up! We’re thrilled to roll out versions 2.16.0 and 2.16.1 together, bringing compatibility, polish, and reliability improvements across the board.
Key Highlights
- PodiumConnect/Micro Compatibility
Support was added for PodiumConnect/Micro, both in the setup views as well as the WiFi / Telemetry configuration pages:
- Refined User Experience
We’ve tuned up the user experience of the app:- Better looking defaults for the triple bottom gauges in the default dashboard for at-a-glance telemetry
- Improved track-selection lists and setup-wizard visuals
- Touch-friendly chart markers that stay visible above or below your fingertip on mobile
More features and fixes for 2.16.0
While the full changelog is available in our docs, here’s a quick roundup of the major enhancements:
- WiFi Telemetry Configuration – enables WiFi telemetry for PodiumConnect/Micro.
- System Channel Defaults – new built-in defaults for wheel speeds, transmission and differential temps.
- Video & Trackmap Gauges – added mute/unmute, “zoom to fill,” generic “No trackmap loaded” fallback, auto-hiding controls, and more reliable performance.
- Stability & Reliability – smoother lap lists during window resizing, more robust USB connections on desktop, and guards against display failures in raw-channel gauges.
What’s Fixed in 2.16.1
We’ve squashed the remaining glitches to keep you focused on racing:
- Track selection now works flawlessly in lap recalculation, setup wizard, and elsewhere.
- Pit-stop timer help text is crisp and clear.
- Mobile chart value markers correctly reposition above or below your touch point.
Available on all platforms. Seriously.
The RaceCapture app runs basically everywhere. If you’re on mobile, it probably auto-updated to the latest version!
Download links:
Android: Download from Google Play
iOS: Download from the iTunes App Store
Amazon Fire: Download from the Amazon app store
Windows: Download Direct
OSX: Download Direct
Linux: Download Direct
Raspberry Pi: Download Direct or re-install using install script
Full Change log
==2.16.1== * Fix: Resolve issue selecting a track in various areas of the app (lap recalculation, setup wizard) * Fix: Clarify language for pit stop timer help description * Fix: Update Telefonica O2 UK APN description to Pay&Go * Fix: Ensure chart value marker is visible above or below the touch point on mobile devices ==2.16.0== * Added support for WiFi telemetry configuration. * Added PodiumConnect/Micro to the setup wizard. * Added more system channel defaults (WheelSpdLF, WheelSpdRF, WheelSpdLR, WheelSpdRR, TransTemp, DiffTemp). * Visual improvements in race track setup, tracks selection lists and various dialogs. * Modernized default dashboard with triple bottom gauges. * Enhanced video gauge: added mute/unmute buttons, "zoom to fill" feature in settings, and improved reliability. * Enhanced Trackmap gauge: show a generic trackmap with a "No trackmap loaded" message when data is unavailable; improved zoom control behavior and controls now auto-hide when not in use. * Fixed pit stop timer popup not showing * Improve USB connection reliability for desktop builds * Fixed lap list stability, preventing breaks or disappearance during window resizing or maximization. * Optimized gauge resizing to ensure accurate scaling and prevent excessive resizing. * Fixed issue with Lap Time gauge to correctly show `--:--.---` when no data is available. * Added guards for display failures in raw channel gauges. * Fixed bug preventing dismissal of the analysis session edit dialog. * Fixed flashing issue on some specific RaceCapture devices
