We’re excited to announce the release of firmware version 2.21.0 for RaceCapture and PodiumConnect systems! This update brings powerful enhancements for data logging, analysis, and reliability—plus native support for the brand-new PodiumConnect/Micro.
⚡ What’s New in 2.21.0
✅ PodiumConnect/Micro Compatibility
Firmware 2.21.0 adds full support for the ultra-compact PodiumConnect/Micro, delivering powerful real-time telemetry in a tiny, ruggedized package.
? Native Best Lap + Lap Delta
BestLap and LapDelta calculations are now built directly into the firmware, ensuring BestLap and LapDelta are always calculated, even if running headless (no connected app). (BestLap and LapDelta are currently calculated within the app, but will be deprecated in an upcoming release)
? Persistent Best Lap Tracking
If you’re running a RaceCapture or PodiumConnect with SD / flash storage, your best lap is now saved to the SD card automatically—per track. When you revisit a circuit, your best lap is already loaded and ready to compare.
? New Lua Scripting Functions
You can now store persistent variables using Lua scripts with the new saveVar() and loadVar() functions—perfect for tracking cumulative stats or customizing behavior between sessions.
? Smarter SD Card Management
If your SD card is nearly full, RaceCapture will automatically clean up the oldest log files to ensure continuous logging without manual intervention.
? Telemetry Defaults Refined
Cellular telemetry background streaming is now off by default, and triggered by the automatic logging start/stop. So you can enable it when you’re actually racing, avoiding accidental data usage.
? Faster Log Startup
Large SD card with hundreds of log files? No problem. Logging now starts faster and more reliably, even when your card is packed.
?️ Improved Log Button Handling
Debounce logic for the log start/stop action button is refined, preventing unintentional triggers.
? Smarter Auto Logging
Auto-start/stop logging thresholds have been tweaked to make more sense for real-world situations, helping ensure you capture the data you care about—without over-logging noise or dead time.Get the latest app
How to upgrade firmware
Step 1 – backup your current configuration
Step 2 – Download the firmware for your device
Step 3 – Upgrade your firmware
Step 4- Restore your configuration
Full changelog
=2.21.0=
* Support for PodiumConnect/Micro
* Add native support for BestLap and LapDelta calculations
* Save BestLap to SD card based on detected track
* add Lua functions for saving variables to SD (saveVar, loadVar)
* Automatically clean up SD card if it is close to full
* Set cellular telemetry automatic background streaming to off by default
* Start SD logging more efficiently when there are many log files present
* Improve debounce logic for log start/stop action button
* Refine auto-start/stop logging threshold to be more useful
Hey there just seeing so if I got a 1967 Plymouth would I able to use this and use obd2 so I can connect the digital dash??
Hi Mitch, if you’re mentioning OBDII, it sounds like your Plymouth has a more modern engine? What year is the engine / ECU?
In any case, then yes – we can read OBDII data with our products.
Both RaceCapture/Track and RaceCapture/Pro can perform these functions.
https://www.autosportlabs.com/product-category/race_capture_data_acquisition_telemetry/
RaceCapture/Pro adds the ability to read sensors directly (not OBDII or CAN bus) – perfect for older cars that don’t have modern electronics or OBDII.
