UPDATE!
Note, we had a bit more work to do on fixing the issues for PodiumConnect/Micro – please update to 2.22.2 for best CAN stability and performance!
CAN bus performance and stability enhancement for PodiumConnect/Micro
Specifically for PodiumConnect/Micro, we’ve improved CAN bus reliability when running under a high CAN bus load and/or marginal CAN bus conditions where a high number of CAN errors are observed. We recommend all users upgrade to 2.22.2 2.22.1 immediately to ensure accurate and consistent CAN bus communications.
Fix for setting Bluetooth name/password for RaceCapture systems
Specifically for Bluetooth-enabled RaceCapture systems, we’ve fixed a case where there was a problem setting the Bluetooth name / password. If you are experiencing this issue with your system, the 2.22.2 2.22.1 firmware will address it!
How to upgrade firmware
Step 1 – backup your current configuration
Step 2 – Download the firmware for your device
Step 3 – Upgrade your firmware
Step 4- Restore your configuration
Full changelog
2.22.2=
* Fix: Further updates for CAN1 reliability and recovery during high bus load / high error rate (Po>
=2.22.1=
* Fix: Allow BT password to be changed (RCP_MK2,3,4 / RCT_MK2,3 / RC_apex)
* Fix: Enhance CAN1 reliability & recovery during high bus load / high error rate (PodiumConnect/Mi>
