Good news, we have plug and play integration cables available now to make it super easy to connect your ECU and data system to PodiumConnect or RaceCapture motorsports real-time telemetry systems.
DTM4 integration cable for Motec / Haltech / Link / AEM and other systems
Our DTM4 plug and play integration cable interfaces these systems with our plug and play harness ecosystem. DTM4 connector and retainer clip are included.
Interestingly, there’s no single standard for CAN + power between systems, but we did the research and broke it down here:
MoTeC:
P1 – Ground
P2 – CAN low
P3 – CAN high
P4 – Power
Haltech:
P1 – power
P2 – Ground
P3 – CAN high
P4 – CAN low
Link:
P1 – Power
P2 – Ground
P3 – CAN Low
P4 – CAN high
AEM:
P1 – CAN high
P2 – CAN low
P3 – Power
P4 – GND
Get it today in our online store
Holley Dominator / Terminator ECU integration cable
Our integration cable for Holley Dominator / Terminator ECU features the Molex MizuP25 connector compatible with the Holley ECU standard. It’s designed to make it easy to plug into the pre-assembled harness you’re using for your build right into our plug and play harness ecosystem, saving valuable time!
Get the Holley ECU integration cable in our online store
AIM integration cable
The AIM integration cable allows for easy connection to the common AIM expansion hub found on all AIM systems. This allows PodiumConnect and RaceCapture to tap into the SmartyCam data stream for instant access to many data channels, plus the ability to map more data channels for RS3 compatible systems.
Get the AIM integration cable in our online store
NMEA2000 integration cable for Lowrance / Marine applications
For marine and many off-road applications using a Lowrance naviation system, we have a NMEA2000 integration cable to make it easy to tap into the CAN bus data stream provided by marine navigation systems, such as the Lowrance Point1 GPS receiver.
