Lap timing and GPS on your Haltech IC-7 dash with RaceCapture
The Missing Link: add predictive lap timing to your Haltech IC-7 dash with RaceCapture, plus Podium real-time telemetry to your pit crew
If you run a Haltech IC-7 dash, you already have a rugged, great looking display. Now you can put real lap timing on it. With our new Haltech IC-7 dash broadcast scripting preset, RaceCapture sends predictive lap times, lap delta, lap count and GPS data straight to your Haltech dash over CAN bus, where they show up as native Haltech channels you can drop onto any screen.
And the connection works in both directions: the same cable that feeds lap timing to the dash also brings your Haltech ECU data into RaceCapture, where it can be logged and streamed live to your crew on Podium.
RaceCapture/Track and Haltech IC-7 dash connected by CAN bus: lap timing and GPS to the dash, Haltech ECU data back to RaceCapture and on to Podium real-time telemetry
What it can do
Once the preset is loaded, RaceCapture broadcasts the following to your Haltech dash, ten times per second:
  • Current lap time – the running time for the lap you are on
  • Last lap time
  • Best lap time
  • Predicted lap time – where this lap is heading, updated continuously around the lap
  • Best lap delta – how far ahead or behind your best lap you are right now, ready to drive a delta bar
  • Number of laps
  • Session time
  • GPS speed
  • GPS position – latitude, longitude and altitude
  • GPS satellite count
This means the predictive lap timer in RaceCapture, with its track database and auto track detection, becomes the lap timer for your Haltech dash. There is nothing to calibrate and no beacon to set up: roll onto a known track, and the times appear.
Lap timing and GPS channels RaceCapture sends to the Haltech dash 10 times per second
How it integrates
Haltech dashes already know how to display lap timing and GPS data: Haltech defines a set of CAN bus messages for exactly this purpose. The scripting preset teaches RaceCapture to speak that same language.
A short Lua script running on RaceCapture reads the lap timing and GPS channels, converts them to the units Haltech expects, and broadcasts them on the Haltech CAN bus at 1 Mbit. On the dash side, you enable two options in Haltech’s NSP software and the channels become available. There are no custom CAN definitions to type in on the Haltech side.
Because it is all on one CAN bus, the integration is a single cable between RaceCapture and your Haltech CAN hub.
Wiring diagram: Haltech ECU and IC-7 dash on the Haltech CAN hub, DTM4 integration cable to RaceCapture
RaceCapture/Track and RaceCapture/Pro
New to RaceCapture? Here is the short version of what the two systems bring to your car, beyond feeding your dash.
RaceCapture/Track is our compact real-time telemetry system. It is designed for cars that already have their sensors on a CAN bus or OBDII, which makes it a natural partner for a Haltech ECU and dash: it adds sub-meter GPS, predictive lap timing and live telemetry without adding a wiring project.
RaceCapture/Pro is the full data acquisition system. It does everything above, and adds analog, digital and output channels for wiring in your own sensors directly, for cars where not everything lives on the CAN bus.
Features at a glance
RaceCapture/Track
  • True sub-meter, quad constellation GPS with L5 band support
  • Predictive lap timer with real-time feedback against your best lap
  • Dual CAN bus networks, with up to 100 mapped sensor channels
  • Plug and play OBDII, with up to 20 OBDII channels – and you can mix OBDII and CAN data
  • Onboard 6-axis accelerometer and gyro
  • USB, Bluetooth and WiFi connectivity
  • Preset library for a wide range of ECUs and CAN devices, including Haltech
  • Real-time telemetry streaming to Podium
  • Direct integration with our TPMS sensors
  • Works with our heart rate sensors for biometrics and driver ID
RaceCapture/Pro
  • 25Hz multi-constellation GNSS (GPS, GLONASS, BeiDou, Galileo)
  • Predictive lap timing with hundreds of tracks available worldwide
  • Dual CAN bus up to 1 Mbit, with CAN termination you switch on and off in the app
  • Analog, digital and GPIO output capabilities for direct sensor wiring and control
  • 6-axis accelerometer and gyro
  • WiFi and Bluetooth onboard
  • Lua scripting for custom logic and CAN integrations like this one
Both systems use the RaceCapture app on Android, iOS, Windows and OSX for setup, dashboards and analysis, and both connect with our plug and play wiring harness system.
RaceCapture/Track vs RaceCapture/Pro comparison
Podium live telemetry integration
When does data matter most? During the actual race. Both RaceCapture systems stream live to Podium, our real-time telemetry and analysis platform, and with the Haltech ECU preset loaded, that stream includes your engine data.
  • Watch the car live from the pit wall, or from anywhere. Your crew can keep an eye on temperatures, pressures and other critical channels while the driver focuses on driving, and catch a problem before it ends your race.
  • Coach the driver while they are still in the car. Compare the current driver’s live data against a reference lap and see where the time is going, in real time.
  • Plan your changes before the car comes in. You only have minutes between sessions. See what the car is doing while it is on track and have the adjustment ready.
  • Share and compare. Share laps with teammates, friends and coaches, wherever they are.
Step by step: connecting RaceCapture to your Haltech dash
What you need
  • A RaceCapture/Track or RaceCapture/Pro
  • A Haltech IC-7 dash on current NSP firmware (we tested with 2.36.0), and a free port on your Haltech CAN hub
  • Our M8 to DTM4 integration cable
  • A laptop with Haltech NSP, and the RaceCapture app
1. Get the DTM4 integration cable
M8 to DTM4 integration cable for MoTeC, Haltech, Link, AEM
The M8 to DTM4 integration cable connects RaceCapture to systems that use the DTM4 connector, including Haltech. The cable comes with the DTM4 housing and retainer clip, and you insert the pins to suit your system. For Haltech, the DTM4 pinout is:
  • Pin 1 – Power
  • Pin 2 – Ground
  • Pin 3 – CAN high
  • Pin 4 – CAN low
Haltech DTM4 pinout for the integration cable: pin 1 power, pin 2 ground, pin 3 CAN high, pin 4 CAN low
2. Plug it into RaceCapture
Connect the M8 end of the cable to the M8 connector on your RaceCapture. If you already use our plug and play harness, the cable plugs into a free M8 port on the harness.
3. Plug the other end into the Haltech CAN hub
Connect the DTM4 end to a free port on your Haltech CAN hub. RaceCapture is now on the same CAN bus as your Haltech ECU and dash, and also receives power from the same connection.
4. Set RaceCapture CAN1 to 1 Mbit, termination off
In the RaceCapture app, go to Setup, then CAN Bus. Set CAN1 to 1M baud to match the Haltech CAN bus, and turn CAN1 termination off. The Haltech CAN network is already terminated, and adding another terminator can cause bus errors.
RaceCapture app CAN Bus settings with CAN1 at 1M baud and termination off
5. Load the Haltech IC-7 dash broadcast scripting preset
Still in Setup, go to the Scripting tab and press the Presets button, then choose Import. In the Import window, select the Shared tab, type “Haltech” into the search box, and select Haltech IC-7 dash broadcast. Press Import to load the script. Also make sure lap timing and GPS are enabled in your RaceCapture configuration, since these are the channels the script sends.
RaceCapture app shared preset search for Haltech
Haltech IC-7 dash broadcast preset selected in the RaceCapture app
6. Load any other CAN mapping, such as the Haltech ECU
This is the other half of the integration. Under CAN Mapping, load the Haltech ECU preset to bring RPM, temperatures, pressures and the rest of your engine data into RaceCapture, ready for logging, your RaceCapture dashboard and live streaming to Podium. Add any other CAN presets you need, then write the configuration to your RaceCapture.
7. Enable lap timing and GPS on the Haltech dash
Connect to the dash with Haltech NSP. Under Connections, CAN, open the Haltech CAN System settings and find Track Modules. Enable both GPS Enable and Lap Timer Module Enable. NSP will ask to reboot the dash to apply the change.
After the reboot, the lap timing and GPS channels are available in NSP. Add them to your dash screens the same way as any other channel: a large predicted lap time, a delta bar, last and best lap – it is your dash, design it the way you like.
8. Load our lap timing dash layout (optional)
To get you going quickly, we have put together a ready-made IC-7 dash configuration for Haltech NSP that includes a dedicated lap timing screen, complete with a predictive delta bar.
Download the Haltech IC-7 lap timing dash layout (.zip)
  • Unzip the download. Inside is a single .nexmap file, which is the Haltech NSP configuration format.
  • The layout was built for the IC-7 on NSP firmware 2.36.0. Update your dash firmware first if it is older.
  • Loading a .nexmap file replaces the configuration currently on your dash. Save your existing dash configuration in NSP first so you can go back to it.
  • Connect to your dash in NSP, open the .nexmap file, and apply it to the dash.
The layout is based on the factory default screens, with the lap timing screen added. Use it as-is, or as a starting point: copy the lap timing gauges into your own layout and arrange them the way you like.
Haltech IC-7 lap timing screen with delta bar, last, best and predicted lap times from RaceCapture
9. Where to go from here
The rest of the RaceCapture documentation covers everything else you can do with the system:
Initial testing
Before you head out on track, a few minutes in the paddock will confirm everything is talking.
In the paddock
  1. Power everything up. Turn on the car’s electrical system so the ECU, dash and RaceCapture are all running.
  2. Check the ECU data in RaceCapture. Open the RaceCapture app dashboard. If you loaded the Haltech ECU preset, you should see live values such as coolant temperature and battery voltage. This confirms the cable, the pinout and the 1 Mbit setting.
  3. Check for script errors. In Setup, Scripting, look at the script log window. It should be quiet. An error message here means the script is not running.
  4. Check GPS on the dash. With the car outside under open sky, give RaceCapture a minute to get a GPS fix. Put the GPS satellite count on a dash screen: once it shows a realistic number rather than zero, data is flowing from RaceCapture to the dash.
  5. Check the lap timing channels are there. In NSP, search the channel list for “lap”. The lap timing channels should be listed. They will read zero until you complete a lap.
On track
  1. Drive an out lap. RaceCapture detects the track automatically. When you cross start/finish for the first time, the current lap time starts counting on the dash.
  2. Complete a full lap. The lap count goes to 1, and the last lap and best lap times fill in.
  3. From the second timed lap on, the predicted lap time and delta come alive, showing how this lap compares to your best as you drive it.
If something is not working
  • No lap timing channels in Haltech NSP: confirm both Track Modules options are enabled and that the dash was rebooted afterwards.
  • Channels are there, but nothing updates: check that CAN1 is set to 1M baud, the script is loaded with no errors in the log, and the DTM4 pins match the Haltech pinout above. CAN high and CAN low swapped is the most common wiring mistake.
  • The ECU or dash starts showing CAN errors after connecting RaceCapture: check that RaceCapture’s CAN1 termination is off.
  • GPS data shows, but no lap times: make sure lap timing is enabled in RaceCapture and that your track was detected. You can check this in the RaceCapture app.
Paddock checklist for initial testing
Get started
The Haltech IC-7 dash broadcast preset is available now in the RaceCapture app. If you already run RaceCapture alongside a Haltech dash, all you need is the DTM4 integration cable.
New to RaceCapture? Take a look at RaceCapture/Track and RaceCapture/Pro, and see what real-time telemetry can do for your racing.
Running this on your car? We would love to see your dash layouts – share them in the Podium community forums.
